Markoneswift
Quartz locked n ready to rock
Hi all - I'm restoring a lovely old Rogers Ravensbourne integrated amp, but I a problem with the power supply. There are four thermistors between the transformer secondary windings and the rectifier diodes. All of these thermistors - Mullard VA1033 - have crumbled away to dust.
What I'm thinking of doing is replacing them with similarly rated resistors - just to get power into the amp, so I can check / verify other areas. Would there be any major concerns about this approach? I appreciate that the thermistors are there to control thermal runaway etc but I'll only be running it to test and not under any load.
