Rookie refoam question
s4v8
AK Subscriber
I'm preparing to refoam a set of Boston A70's and have a quick question the glueing procedure. When glueing the foam to the cone do you usually apply the glue to one surface or both surfaces? I'm asking because one of the foam vendors (Midwest, Simply Speaker) had a page that I can no longer find, where it mentioned it was important to apply to one side only, maybe because less is more when applying?
I apply a thin application to one side only. You don’t want to apply to both sides or you will have too thick of a glue application, causing an excess of glue being squeezed out when you put both sides together. You will then have to clean that excess and chances are you’ll make a mess of it.
