ViperZ
Well-Known Member
I'll start documenting repair of my Rotel RA-1412 integrated amplifier. Sometimes it would just kick into protection randomly.
Settings that I am measuring at: all tone controls are in 'out' position. AUX input is selected.
I checked voltages on both power supplies, and all voltages are present.
When amp and preamp sections are disengaged from each other, DC offset on both channels does not exceed 20mV, with no input signal.
When I connect preamp to amp sections, DC offset would randomly jump to different values for a very short time. I have seen it as high as 1.2-1.4 VDC, and protection did not engage (too slow?). I monitored each channel for a few minutes. Protection does catch up eventually, maybe to higher or maybe to longer spikes.
The strange part is that it is happening on both channels, so the cause must be something common to both channels...
I assume the problem originates from tone control amp board, not from phono and mic board, since Aux input is selected.
I'm not sure what could cause such problem in both channels. I'll start monitoring supply voltages to that board tomorrow.
If anyone has seen such problem on Rotel and can point me in the right direction, I'd really appreciate it. Thank you.
