Hi All
Rotel RA-935BX amplifier (c.1993) in need of new toroidal PSU. No Rotel spares available; transformer is shorted on the primary winding.
Rating plate power is 300W so I'm assuming 300VA transformer?
Fitted unit (TT-279GF) is 2x 28.2V centre-tapped 110mm x 51mm. There is no space for a bigger transformer. I can't find any 300VA units that small.
The amp is only 40W RMS into 8 ohm (x2), various calculators seem to suggest even 160VA should be enough.
I will be replacing the electrolytics whilst I'm there, with:
Any and all input very much appreciated.
- PSU 8200uF - nichicon BK
- Smaller Signal Caps - ELNA SILMIC II
