Dazaa
Got my hands on this beautiful totl integrated, but it has a few issues. Initially the left channel was very quiet, cleaned the switches and it works fine with headphones. The right channel is totally dead, both fuses blown, new ones blew instantly. Pulled the 4 2SD426 outputs and 3 test fine, one is showing continuity in all the places it shouldn't so I assume it's dead. I'm guessing that simply swapping in a new output transistor won't solve the issue. Should I pull the amplifier board out and start testing all the other transistors? The service manual says that if the fuses are blown it could be shorted caps (no problem since it will all be recapped) shorted rectifiers (I assume these are 4 large diodes on the output stage?) or a faulty output transistor (which is obviously true). How should I continue this repair? Pulling and testing the rectifier and other transistors on the output stage?
Any advice appreciated.
Edit, looking at the schematic, the fuses and rectifiers are actually on the power supply board for the right channel.
