Rotel RB981 speaker impedance handling 2 ohm?
TellMeWhy
Dear friends, I recently acquired a subwoofer to compliment my Kef 103.2 speakers. It's a Canton Plus C from the late 1980's and though nominaly rated at 4 ohm, the guy at Canton tells me it's 4 ohm with the satellite speakers connected, and only 2 ohm as a sub alone! I don't have the satellites and wouldn't want to use them anyway....
So my question is, using this wired in parallel with the 8 ohm Kef 103.2's, with a resulting combined impedance of 2.66 ohm (my caluculation) at modest listening values, am I likely to do any damage to the Rotel RB981? I know the Rotel is a powerful, high current amp, but I also know this isn't recommended. What do you think? Any ideas or way of introducing a dummy load on the satellite outputs? I hope I can make it work because I love the sound of the sub! Thanks, Jon
If that impedance really is that low it can't be good for that amp. It doesn't make sense that the impedance drops with less speakers connected.
