No pics to post currently as I'm away for work, but I started noticing a buzzing during quiet passages of music. Initially I thought it was the power amp, however, I narrowed it to the pre. Opened it up today,and the only thing I saw that looked suspect was a couple resistors near a darker section of the board. I initially thought they burned up, but upon removal, it almost looked like, dried glue. But why just two resistors. It was definitely some substance, but the Rs tested perfectly fine. I did end up replacing three of the 4 in question and a couple caps in the PS and the buzz is gone. So, not positive about which the cause of the buzz was, but two of the caps were 17% low in value and may have some leakage around the legs. Components in question follow:
C926,927 TK brand 100uF/35V were the low value caps at IC902,902 voltage regulators. Replaced with Panasonic FM 100uF/50V
C924 TK 470uF/35V checked out fine, but still was replaced with a Nichicon HD 470uF 50V cap. 1000/50 was too big to fit the area easily.
C451,452 TK 4.7uF/25V BP were replaced with Nichicon ES 4.7/25V
The resistors that were in the "glue" were
R534 10K and R520 22K
R526 10K appeared to have a light grey spot on it, as if it had been exposed to something
R532 10K was clear, but since in the same circuit as R534.
R532, R534 and R520 were replaced with 1/4W MF resistors and the clean R532 replaced the "spotted" R526.
