Rotel Rcd-951 RestoMod, saw this player advertised not working, spares or repair for £50, bought it as something to do, a bit of fun, and a bit experimental trying film coupling caps instead of electrolytics.
The player is about 10-20 years old, it offers :-
It powered on but the tray was firmly stuck.
Bonus on first opening the case below, it came with a free cd!
Fairly dusty but no smoke smell, gave everything a good clean including the laser lens, rod, laser rack and tracks but despite re-lubing all, the tray would not run free.
Boiled the belt to shrink it slightly for more grip, after much head scratching eventually found that the little cog bar runner underneath the tray at the front was rotating but not freely, it had been shoved down out of its proper place, levering it up it clicked into place and the tray then was back to gliding in and out.
Capacitor porn! Black gates(BGs) everywhere, these caps are legendary, there's 2xFK (low iron) 100uf 25v line level coupling, and about 8 other F type powering the opamp 100uf and dac 47uf. The higher model RCD-971 contains even more.
The light blue ones nearest are Panasonic. What a quality thing though even the blue film caps around the opamps are mounted high on legs presumably for isolation.
On testing the laser read ok, and the player sounded quite good. I would imagine it would improve over time because who knows how long its been inactive and black gates take weeks to form nano tubes and come on song.
Decisions, decisions, leave the BG FK coupling caps in place, replace them with Nichicon ES or Audio Note Seiyru or polymers, anyway went with the big yellow Vishay 1813 MKT film caps 3.3uf nothing special, bypassed with Vishay 1837 MKP 0.1uf under the board. Using the Vcap coupling capacitor calculator, 3.3uf is ample for not much bass roll off at all at 20hz. The other aspect is film caps don't distort whereas electrolytic capacitors do. It's important to secure the film caps to the board with glue as any movement is likely to break the tracks off the board. If only they were made with longer more flexible legs. Polyester film caps can sound a bit grainy/fuzzy for the first few hours or ten, normally there's a point when they smooth out and bass deepens.
Black gates replaced with 35v Panasonic FC (blue and gold) and a few FM, they are tiny compared, is this sacrilege? Well the BGs go on to live another life where they may be appreciated more. One Muse KZ in the dac vref position. The Pacific chip, opamps etc are static sensitive.
The opamps, although they are served by 4 electrolytics they were not bypassed so added two ceramic 100nf's under the board. Maybe it's not necessary with BGs.
Changed out the 1n4003 regulator diodes for fast diodes SBYV27-100-E3, these are very overspec at 100v 2 amp. Might be wrong because there were other changes involved, but suspect this was very worthwhile.
Only now notice that that 2 watt resistor is bang up against the blue cap, so I need to go back in and move that away it must have been like that for 20 years so hopefully not too bad. Also a black spot on a ceramic cap.
Changed out the caps on the signal processor C164, C151 not pictured, always worthwhile.
Overall result, moving the coupling caps to film makes a massive change for purity (no distortion), soundstage, separation, scale, yadda yadda, anyway definitely very worthwhile for transforming any cd player.
Comments, extra suggestions, things I've missed, welcome.
- hdcd compatibility.
- an 18 bit dac.
- opa2604 opamps.
- reliable Sony KSS-213c mech.
- (shhh) it's full of black gate capacitors.
- Very spacious, high quality pcb. No tiny SMT components.
- Originally about £300-£500. Base unit in the range with 971 and 991 above.
