There are a couple threads about this. Not with lots of folks posting but this topic shows up and some folks post.Could be an entire thread with older table owners posting results, would be fun.
I was, but it's nearly ten years old and I wasn't happy with the Speed Test results. What's shown is with a new belt in place.That's an amazing result. Are you running the original belt?
Proly the only reliable measurement in this thread and threads like this.I used a stopwatch and a strip of paper and did it the old school way.
RPM Speed Test on my modified SOTA MOONBEAM belt drive turntable yielded these results:
00.04% wow and flutter 1.2% fast @ 33rpm
00.09% wow and flutter 1.48% fast @ 45rpm
RPM Speed Test is an Android cellphone app. The results when used with a well worn belt weren't nearly as tasty.
My comments:
3. The app is very tricky because it requires you to place a heavy unbalanced object (the cellphone) on the platter. Thus it will measure nice on turntables with massive platters and/or strong motors and/or servo control (like most DD tables), and bad on turntables that don't have any of those features.
The rpm app tests for wow and flutter are not even close to accurate.RPM Speed Test is an Android cellphone app. The results when used with a well worn belt weren't nearly as tasty.
This hasn't been my experience. If I center the phone over the spindle it gives a very low wow reading on my light-platter DP-15F.
I certainly hope they measure 3x the original spec.The rpm app tests for wow and flutter are not even close to accurate.
Chris
The point is you are not measuring wow and flutter of a rotating record on your platter. If a record has for example an off centre hole then you get wow, the same apples if the bearing has play or the platter is warped, non of these things will affect the app. We dont know where the gyro is in the phone as already mentioned so we cant centre it on the record and unless your phone is round with a hole in it it is impossible to get it balanced anyway. The apps are a bit of fun, you can get a reading and compare it to after changing a belt and get another reading, these are not the real value not even close but you will maybe see the change has done something that is the best the app can do.This hasn't been my experience. If I center the phone over the spindle it gives a very low wow reading on my light-platter DP-15F.
see my other postI certainly hope they measure 3x the original spec.
