The Elans were one of the best sounding RSL models offered and are highly regarded by the people here at AK that own a fully functional pair. It's well worth it to take the time to diagnose the source of the problem and repair it. Also the "crackling" could possibly be from the receiver/pre-amp/amp being used to drive them, or a bad or loose wiring connection, so all possible sources need to be investigated.
One the back of the cabinet near the top is a 12" passive radiator flat cone with a foam surround that will deteriorate over time that will need replacement and when the surround fails it can make strange noises as the flat cone moves around. Also, the midrange and tweeter level control potentiometers will always corrode over time and cause crackling noises and volume drops (or cut-outs) and are your most likely culprits. They would need to be loosened so you could access them behind the front baffle board in order to spray De-Oxit into all of the openings in the potentiometer metal casing and then you would turn them back and forth many times to make sure the De-Oxit gets spread around inside to dissolve the corrosion. Once you pull the knobs off in a straight out direction there is a thin nut on the central shaft which holds them in position to the cabinet. With the woofer removed you can then access the potentiometers for "treatment".
Even if you decide to go with thinner speakers by repairing the Elans to fully functional condition you would then be able to sell the pair for a much higher price which usually runs at least $ 400 a pair these days and usually higher (typically in the $ 500 to $ 700 range here in LA.).
