Running speaker wire during remodel question.
Bucky Badger
AK Subscriber
Hi Guys and Gals, have a question for ya. My wife and I are remodeling our house and it's getting time to think about running speaker wire. I bought 300' of 12ga. OFC from Monoprice and was going to run this wire either under the floor or over the ceiling starting from where I will be setting up my gear. I will have 2 runs of approx:75'. 2 runs of approx: 40' and 2 runs of approx 20'.1 run to a pair of outdoor speakers.75' run. 1 run to one side of the room and the other run to the opposite side of the room.
1) While watching a utube video I saw a guy using what appeared to be something 'like' Cat6 cable to run under the floor and up to the wall plate. Should I be using that instead of the 12ga I bought or will the 12ga be ok???
2) I have been looking at wall plates something like this.
They are cheap, gold plated, will accept 12ga wire and look like they would do the job. Is there a better product I should think about using? I will probably be terminating the wire with spades and attaching them to the backs of the wall plates binding post's and mounting them to the walls.
Any help or insight is greatly appreciated.
"CATx" wire isn't made for speaker cable. It's made for computer/control signals. For speaker wire, stick with that 12 gauge wire you bought.
Definitely you need to use approved cable for in wall use. Nothing should be inside a wall that doesn't meet code. Can you exchange it?
If it looked like Cat6 it was probably multiple conductor wire that is rated for in wall use:
Getting it in 4 conductors or more is convenient for making less runs.
I used those wall plates from monoprice in my space and they work great and look tidy, just think about future flexibility when you lay them out if that matters. When we decided to rearrange and get new furniture 4 years after I installed them the location of the speaker plates was no longer ideal, I made it work but I could have laid them out with greater flexibility originally
And, imo, it isn't worth not meeting code, even though that might be tempting since you apparently already bought the wrong cable.
Listen to these two guys. If you have a fire, get struck by lightening or experience any calamity insurance companies usually refuse to pay if any of your in wall wiring isn't up to code. This doesn't apply if you run it under a rug or down a baseboard.
12 gauge is a bit overkill, ain't it? I used 16 gauge here with 50 foot runs - no problems. Belkin audio, twisted two conductor, zero-oxy, extra shield w/drain, and wall rated ...
Wow. Thanks so much for the info you guys. Glad I asked the question but sorry I didn't ask sooner. I will have to check back to see if I can return what I bought.
Yes 12ga is a bit of overkill sKiZo but I have read that with longer runs you want as thick a wire as you can get. I knew I would have runs at least 75' so I wanted to cover my arss.
We are putting in hardwood floors so either under the floor or over through the ceiling are my options but going the baseboard route might be an option as well.....
Thanks again for your sage wisdom AK. You are, and always shall be, my friends.
How thick is the hardwood? I've seen where you just notch a board and trap the wire when laying it. Same thing with baseboard runs, only different. Probably best not to nail through it, eh. <G>
Lot would depend on what you're planning for speakers and power as well. My setup is all just ambient background music except for the main listening room, so the smaller gauge is fine.
PS ... gauge recommendations are all over the place. Here's a decent chart that should get you in the ballpark ...
http://faq.yamaha.com/us/en/article/live_sound/pa_systems/stagepas_300/2521/7034
Just a suggestion. Try to not have you cable right next to power cables and if you can help it , when, if they cross power cables try to have them cross perpendicular if possible.
If I was going to run a wire in a wall (and I have), I'd use stranded THHN in conduit.
https://www.distributorwire.com/blog/thhn-xhhw/
PVC is easy to install, but EMT conduit is metallic and will provide additional shielding from RF.
https://steeltubeinstitute.org/steel-conduit/types-of-steel-conduit/electrical-metallic-tubing-emt/
If the walls are completely open and you have access to the studs, plates and sills, I'd also suggest installing an extra conduit with a pull wire so you can still run another circuit after the walls are closed up. Plan for the future!
. Yes. Good advice here.:thumbsup: Don't be tempted to run your low voltage wires through the same holes in the studs as power wires run through. It may look like an easy thing to do but you will not like the results.
Under/in floor would require same cable spec's as in wall.
Be sure that with any manner of install there will not be the possibility of driving a nail through or drilling through the cable in the future.
Well I just learned something (or I'm incorrectly interpreting this chart). According to this, the gauge recommendations are different for 2/4/8 ohm speakers. 50 feet of 16 gauge wire will be fine for 8Ohm speakers, but you would need 12 gauge to properly wire 4Ohm speakers. Not sure if I'm 100% sold but it seems plausible. Interested in others' opinions.
I believe the white jacketed Monoprice 12AWG is in fact CL-2 rated but the clear zip cord is not. Not sure what you actually bought?
The white jacket stuff was actually cheaper when I set up what's her face's HT so I bought that, the zip cord is definitely easier to deal with but for in wall use the white stuff.
I am checking now. Hope so.
I will def. not put the cable right next to a power cable. Thanks for that alert.
Check. :thumbsup:
Thanks for the chart. I think I will be running the cable along the baseboards. Under the wall drywall and next to the hardwood floor. From what the contractor tells me they leave about a 1/4" gap between the hardwood and the base of the wall.
UPDATE. So, I just went and asked Monoprice if in fact my cable was in-wall rated and he told me to look at the jacket. I just looked on my cable jacket and it does say CL2 on it........ So I guess I'm good to go.
Kinda wish I would have gotten the cable WaynerN suggested but this should work.
Now to get the wall plates ordered.
I can't thank you guys enough for your help. If there is anything else I am missing, or any other helpful tips then please share with me your wisdom.
You guys are Top Notch. :thumbsup:
