I wanted to try some EL34 output tubes in my KT88 amp (running as UL/OT screen tap) but I think they are running too hot checking the voltages. The EL34 tubes caused the B+ to go up a bit, and while I don't see any red plate after playing for about an hour, not sure they will last long running this hard.
They really sound great though lol. The EL34 toned down the highs that are a touch too bright with the KT88, but I think the total plate dissipation at these voltages might be past what an EL34 can live at, even though the ma spec seems OK. Do you think an EL34 can live here? If it matters, these are JJ tubes.
EL34
Plate voltage 465v
Plate to Cathode voltage 430v
35V across a 500ohm cathode resistor = 70ma
KT88
Plate voltage 452
Plate to Cathode voltage 411
41V across a 500ohm cathode resistor = 82ma
EL34
Plate voltage 465v
KT88
Plate voltage 452
