RunOutGroove
Addicted Member
I bought one of these tiny little amps to use as a computer amp (I had it hooked up to Energy eXL 15 and just got some NHT Superone speakers that I'm trying with them). It's a cool little piece of gear and nicely designed. I like the way that it has it's own DAC and digital inputs. The sound is clean and certainly all I want out of an amp that I'm using with my computer (I'm much more critical of my main system).
There's just one issue with it though and I wonder if anyone might know of a fix, let alone an explanation... it seems that when I turn the thing off and back on that it losses the left channel. I thought that it was just a loose speaker connection and messed with that, but I'm realizing that this isn't the problem. I can get both channels to work if I unplug then replug in the power supply and then cycle through all of the inputs (I'm using USB, but had the same issue when I tried using it with the analog inputs). I can always get both channels working after messing with it a bit, but it would be nice if everything would work properly when I turned the thing on. I suppose that I could leave it own and maybe it's not drawing very much power as long as it isn't being used, but my thrifty nature makes me feel like that's an unnecessary waste...
