maxProview
Member
Hello, recently I have bought a Pioneer SA 3000, the power amp work fine, but the Phono board is out.
The Phono board uses 3 pairs of transistor 2Sa978; 2SC1919 2SA912.
2SA978 seem to be ok because the voltage at the base and emitter are in the specs.
All others voltage are out of spec.
I have tested the 1/2W and 2W resistors (R25; R26; R89) they have some sign of hot, but they are OK.
At the + of C64 for example, I don't have 28V but the same 17 pin voltage.
The ground of the board is ok.
I need help to find equivalent for 2SC1919 and 2SA912. Personnaly, i think to choose 512-KSC1845FTA and 512-KSA1220AYS.
What is your option about my board ?
Thank for your help !
