Maybe I can pump some new life to this question. I think this is amp is getting more and more sought after. Where I could buy them for 10-20 Euro's a couple of years ago, now the fetch up to €100 and more.
Just because the gold coloured knobs plates dropped off, people lost the speaker plugs and such, a complete one is hard to find, almost impossible if you want all 4 the speaker plugs.
If the amp has had a total recap and maybe some new transistors in the phono (head) amp or control amp, it can sound really nice and detailed. As said, it's simple, easy to fix and teamed with the TX-500A it sure is a good looker and a good point of conversation.
I predict this one is a sleeper. It'll be harder to pick one up, scarse will make desired.
I think all the x00's from the early 70's are the ones to keep an eye on.
Even as a repair trainer, it'll give you more ideas and know how about electronics.
And yes, a 10,000uF/50V fits perfect in the 3300u holder. Swap the rectifying diodes for something like 4007's or fast recovering ones. It's a rewarding job to upgrade this little darling!
The control board hasn't been touched yet.
Yes. Sanyo 2.2uF..... alarm. Leaking. Reading on the meter was good! But it didn't work. 4.3 volts on pin 4 (yellow wire). Hiss and crackling from the transistors too!
