QSilver
Picked up one of these with a few problems. Had some bad crackle on one channel which i think i have tracked down to the outputs. I pulled out the outputs and the crackling has gone from my scope.
On the left channel, i had a dc offset of 80mv and 20mv on the right. I started working the left channel first and replaced the differential pair with a pair of gain matched KSA992's which dropped the offset to 60mv.
I then swapped out the rest of the transistors for the left channel leaving the outputs disconnected. Despite changing the transistors, checking resistor values, and replacing the eletrolytics and the single tantalum cap, the offset won't drop below 60mv! Im a bit stuck for ideas forth problem now. I've even gain matched the KSA1031 and the KCS2383 in the driver stage with no difference...
I've taken measurements on the bases of Q7 and Q9 which, according to the schematic, should read 0V. Here, they read 88mV each. Compared to 40mV and 32mV on Q8 and Q10.
I think this means that something here is not quite right.... I've even tried removing the decoupling cap C47 to isolate it from the tone circuitry but that didn't help... what am I missing here?
I've replaced the transistors using cross references I found in another 6500II thread here:
http://www.audiokarma.org/forums/index.php?threads/re-do-an-sa-6500ii.614242/page-2
