SA-708 amp + SG-9500 eq + SR-202 reverb. How to?
marini
vinyl-addicted
Hello all,
I have been trying to set up my system using an SA-708 amplifier, an SG-9500 equaliser and an SR-202 reverberation amplifier, to no avail.
For simplicity’s sake, let’s say I have only one tape deck that I connected to Tape 1 on the amplifier, so this “chain” will be using the Tape 2.
I don’t really need to use the reverb to its full potential - no tape deck will be hooked up to it. I just want to be able to apply the effect on the output sometimes.
How would I go about hooking them up?
Appreciate any help.
Thanks in advance.
As a first step if you have a tape deck for the source I think it would be best to hook the tape deck outputs to the Aux or Tuner input of the amplifier.
Then the EQ would be hooked into the Tape 1 location of the amplifier and the reverb would be hooked into the tape section of the EQ.
Hooked up that way you can listen to the tape deck via aux/tuner and switch the EQ/reverb chain in or out if desired via the tape 1 switch of the amp.
Or you can leave the amp tape mon switch engaged all the time and bypass or engage the EQ with it's EQ on/off switch.
If you want a touch of reverb you would use the tape monitor switch on the EQ to switch it in and out of the chain.
Hope this makes sense to you.
Thanks for your suggestion. Yes, I got it.
Yesterday I set it up slightly differently and I'm happy with the result.
I got the reverb hooked up to Tape 1 and the equaliser to Tape 2.
My deck (well, several controlled via an external switch) is also hooked up to Tape 2.
I know this way I either have the equaliser or the reverb, never both, but it's OK.
:thumbsup:
BTW what I poster earlier will work with the tape deck in tape 1. Simply move the EQ/reverb chain to tape 2. This set-up would allow for EQ and reverb at the same time, if that is what you are after.
Either way glad you got something going. :music:
I'm gonna give it a shot over the weekend. There are so many cables here I can't face them again until then. :D
