I was thinking of seeing if TO-3p leads would fit in the batwing socket connections, and a single mounting hole drilled (tapped or with through bolt/screw) to mount it.
step 1: mount the transistor, making sure it is isolated electrically from the heat sink using a mica insulator
step 2: make the connections to the emitter base and collector.
one thought to discuss, the to-3p / to-247 etc mounted on the INNER face of the heat sink (through a pre-existing hole), socket discarded and euro type screw connectors tie the transistor and the wires together (sort of like what was done on the sx-3900).
