M0t0wn
Well-Known Member
Hi, this my first post
Have always preferred Pioneer when I could afford it.
Used to have a silver faced amp but sold it due to a move overseas.
Getting back into it and have just got a SA-9500 from E-bay for the Garage.
Buyer mentioned that the unit has a light hum at low volume but it went away when you would touch it. I notice the opposite. But that is not the problem.
From the start the balance control was real scratchy and the rigth channel was hit and miss. Due to the good deal that I thought i got I decided to deoxit. This had an imediate but slow working effect. I am kind of new to this so I am not sure what to expect. Anyway after turning the balance control a lot of times the scratchiness went slowely away and I was realy happy with the result and felt really good about myself. Next time I turned on the unit the rigth channel did not work. There was however no scratching in the balance control. Turning the unit off and on brougth the rigth channel back. Today I decided to deoxit again and the rigth channel is back, but I have the feeling that it is lower volume than left.
Question for the board;
1. Do I neeed a new balance control and are these available? what should I budget for this including labor.
2. Should I power this unit off and on or just leave it on.
3. At what temperatures should I move this indoor, my garage is unheated in Michigan.
I really like the side location of the connectors, makes it easy to hook it up when you have to change configurations a lot.
I further have a CT-F8282 also with left rigth channel issues (visible in VU meters) and a RG-1, looking to add a TX-9800 or 9500.
Because I wanted to add a CD I just picked up a NAD 5330 at a Garage sale for $10. I was able to test it before I bougth it.
I am using a CT-M5R to listen to my old cassettes that works great.
