AlwaysAnalog
Like many of you I have an SA-9800 with a dim display, which is still somewhat visible and functioning. I have done much reading over the past few months and now understand considerably more than I did but I am a non-electrical type so some of the reading has been confusing.
After many voltage / current checks as suggested by MTF and others, I believe my issue is simply an old display that is drawing more current than it did 40+ years ago. That being said, I plan to implement MTF voltage regulator plan (see Jan 2010 thread below) but wanted to know ...
Question 1: Can use a step down Buck Converter instead of the transistor described by MTF described in the Jan 2010 thread quoted below? For a non-electrical type like me it just seems easier to adjust the output voltage to Pin 10 on the Indicator Assembly board (AWV-002) through the Buck Converter than adding resistors to find the best display results, albeit the converter is a bit more expensive to purchase.
Question 2: I believe the VFD is static driven (i.e. common grid across the display and driven by a single voltage input at pin 10). If that is the case, it seems like I could simply remove the voltage to the grid and allow only the anode (segment) positive voltage to attract the electrons from the cathode (filament) wires. The grid does "defuses" the electrons as they pass through the grid towards the segments so there may be some visual difference without the grid voltage present but maybe not enough to be distracting. This was tried by Backlight in the JAN 2010 thread (see below) but there was no discussion about the issues in doing this. I do realize that the DIM/BRIGHT function will no longer work because that button changes the grid voltage and if the grid voltage is removed than no functionality will exist through the button.
Background information is below for those of you that are new to these threads and have the same issues with their display. Hopefully the below will save you some searching time. ALSO, I think I want to build a drop in LED version of the display. I will start another thread on that subject when I am ready.
https://en.wikipedia.org/wiki/Vacuum_fluorescent_display
What is a Vacuum Fluorescent Display (VFD). Read this to understand how the VFD is made and operates.
JAN 2010: http://www.audiokarma.org/forums/index.php?threads/sa-9800-fluorescent-display-issue.277855/
Definitive thread and worth reading several times. It contains the voltage regulator concept proposed by MTF.
FEB 2013: http://www.audiokarma.org/forums/in...-it-try-to-fix-it-or-flip-it-thoughts.503200/
Contains a reference to clean the "metal contacts" to improve display performance. I could not determine what metal contact being referred to but I did try to clean the contact between the VFD and Indicator Board as well as using Deoxit on the Dim/Bright switch. Unfortunately, no improvement.
MAR 2015: http://www.audiokarma.org/forums/index.php?threads/another-sa-9800-dim-display-issue.650700/
Contains a sentence from MTF that reiterates his belief "as the tube ages, more current is drawn, shifting the voltage points in the original circuit. It's NOT designed for the tube's aging over 30 years!"
JUN 2015: http://www.audiokarma.org/forums/index.php?threads/pioneer-sa-9800-weird-display.664259/
Latest thread I could find on the subject. Interesting read.
