SA202 SoundTube Class AB Mini Amplifier
newriverrat
I have one of these just sitting doing nothing:
This is from their website:
The SA202 amplifier is an ultra-compact, 2-channel amplifier with extra heat sink surfaces for extended duty at full power. Rated at 20 watts per channel output at 4 Ohms with max gain of 35 dB. Dual RCA, stereo mini jack, and high-level inputs. Power inputs include either three-pin Euroblock or barrel connector. 12-volt trigger for automatic on/off functions when source power is detected. Mounting hardware is included and adapts to pole, surface or security attachment installations.
Power per channel @ < 10 % THD: 20 watts (4 ohm stereo) 10 watts (8 ohm stereo
Power per channel @ < 1 % THD: 15 watts (4 ohm stereo) 8 watts (8 ohm stereo)
I'm wondering if any of you folks had this, what could you use it for?
