oz-2
Dear AK'ers
I wonder whether anyone could give me some advice on how to fault find an intermittent protection issue on an SA9500 (mk1)? I will be very grateful for the usual excellent advice and help.
Just to give background.
The amp has been professionally recapped. I splashed out a couple of years ago. Amp, in general very good condition. I think it must be a late version of the Mk1 as the wrap pins are fixed to a clear perspex kind of former.
I couldn't afford to do the known iffy transistors at the same time.
The amp goes into protection intermittently and for very short periods on an irregular basis.
I thought, initially, it was during loud passages of music but not always after observing over a while.
I thought the input level might be too high from CD. Ive turned that down.
I recently noticed a kind of 'rustling' sound at, or just before the amp went into protection. I suspected the 4 2sa726's on the pwr amp board. I replaced them and Q7 and Q8 whilst I was in there with KSA992's and KSC3503's respectively even though Q7 and Q8 were not the dreaded 1451's. I also swapped out the trim pots and replaced those with MTF's recommended Mouser alternatives. The amp set up to 0v balance and 20mv bias beautifully and stably over a long period of watching it. The occasional rustling has gone completely. but every now and then the amp slips into protection and out. Sometimes repeated a lot of times before settling down again. Sometimes it never does it!
Another suspect area is the pwr supply. It has been recapped but not had any transistors replaced. The trim pots have been replaced and adjusted up to set voltage levels.
I use an 8ohm set of spkrs. (Kef Q100's)
So thats whats been done.
My question is really, in view of this, how do I fault find? How can I monitor something to see what's happening? I'm a bit stumped for ideas short of wiring something in to the protection board so I can monitor that but I have no real idea what would work there.
As always, Im grateful that you've even read this far and if you offer any advice even more grateful.
Best wishes
David
Best wishes
David
any amp or power supply work means starting back out at 0 idle current, DBT tickling the dragon's tail, then setting the idle current on straight line power.
