Jailtime
Standin' on a corner
Well, it's gonna be a while before I can get her in shape enough to even think about powering her up, so at the moment, I have no idea what works and what doesn't. However, I've worked on well over a dozen Marantz scope receivers, and to date, I've never seen a dead CRT - so I'm not too worried about this one. On close inspection, there doesn't even appear to be any discolored phosphor (well, maybe just a small center dot), so with any luck, burn-in issues will be minimal as well.
As far as the filter caps - not happ'nin'. These are unobtanium. Wierd working voltages of 105VDC and dual cores (there are actually TWO filter caps in each can); the only way they could be replaced would be through extensive modification of the chassis mounting plate, and the shoe-horning in of four separate caps. The existing filters look pretty good though - no goo oozing out of the bottoms - so perhaps Lady Luck will stick with me in this area as well. I plan to recap most of the rest of the receiver, so the big cans will be some of the only caps I don't replace.
Looks like you dropped by this thread when it was written long ago - http://www.audiokarma.org/forums/showthread.php?t=116273. Still a useful resource though. Some of the Marantz receivers with those damn dual core filters can be modified to accept 4 filters (2285B, 2330B). Doesn't look like this will work with the 2600. Hope your stock filters are still good!
