Goesto11
So I am working on fixing a couple things, SAE 2400L and them a Marantz 4300. Both were push to the limits since my uncle was the one that owned them! I am starting with the SAE 2400L and going to go thru the unit and I am starting with the main output driver board, the unit calls for 2SD424's and 2SB554's transistors which as we all know are made out of unobtainium. So after reading and looking at transistor specs I narrowed it down to either MJ21196G/95G pair or MJ15024G/25G pairs to replace the originals - any input here on which to select or if there is something better please make a suggestion ?!? Many people on forums mention that using certain transistors can cause oscillations in the amp. As I was also taking apart the amp someone added fuses into the +/- 80vdc supply wires - good idea but a real hack job! They also did this on the audio outputs (I think) - anyone know this? On the bottom of the main output board there are 2 large wire wound inductors, whoever worked on it soldered a fuse into it and ran it thru the inductor - not sure if this is stock or not, any input here would be great - see pictures of what I have! There is also a bias adjustment POT on the same board for each channel, there is 330 ohm resistor soldered in parallel with the POT, not sure if this is stock or not, anyone know? The schematic I have is a bit fuzzy, anyone have a good clean one?
