I built a Silicon Chip (Aussie electronics magazine) LP Doctor, an excellent MM phono preamp with an added click detector which delays clicks and pops and blanks them. Trust me, you don’t notice anything missing from the sound, except for clicks – the click suppressor can be bypassed, so it’s easy to compare sound quality with and without. So the members who think you’ll miss anything or reduce resolution are needlessly obsessing about something they won’t miss – it happens so quickly, that the brain just doesn’t register that anything is missing!
Admittedly the LP Doctor is a design from the early-2000’s, so may be better than some of the older click suppressors – having built some phono preamps which are rarely matched by commercial designs for noise, the LP Doctor holds up well as an excellent, quiet MM phono stage, with the added bonus of click suppression. Sadly the Mitsubishi delay chip it used is now obsolete and very hard to find, so it was a one-off that can no longer be built.
Bear in mind that all of my records are exceptionally clean (I own a vacuum RCM), well-stored in clean, new liners, and with sealable plastic external covers inside a purpose-built record cupboard with rubber dust-sealing doors and have been permanently destaticised (using SoundGuard, Permostat, Static Cleaner or AM Record Cleaner), and all have been very well treated (by me, anyway – some were bought used). So they are mostly near-mint quality, but they still somehow manage to pick up a few clicks and pops. The LP Doctor usually catches all of those, so I consider it a good buy and build to improve the sound from my vinyl records.
