Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
from my own experience, that's a red flag. Ranks up there with with "the owner said it worked fine, but I don't have the equipment to test." and some of these sellers have complete stereos amongst their various auctions, but don't have the wherewithal to connect them? Riiight.
I Emailed the guy, And he is swearing the amp is in perfect working order.
Gonna look into it closer. I do know one thing, SAE stuff is built way over what is called for, And after owning a P-250 in the early 80's, They will
hold there own with anything out there, Plus they are very good looking
pieces of gear.
The 501 has problems with the speaker protection thump circut. There's a set of relays that go bad which prevents the amp from engaging the speakers. Also has a delicate bais range...you will know when it needs adjustment...the HF sound scratchy.
Interesting comment. I own nine A501/2401/P250s (different designations for essentially the same amp) and have had only one problem with them, ever - once I had the power LEDs go out on one. That's it. I find it to be remarkably reliable for a 25 year old amp.
