Hi fellow Audiophiles
I am looking to replace the cooling fans in the 2400, 2500 and 2600 SAE power amplifiers. The fans are working properly but are a bit noisy, not mechanically but too noisy due to air movement in a quieter listening environment. I was thinking that a lower cfm fan with a lower noise level would be just fine especially since these are not being driven hard in a pro audio application. I see that they work on AC direct from the mains 120 ac voltage so there are many options. Any thoughts...
Thanks for you help,
Mike
Mike
