Howdy, trying to revive an SAE Mark XXX1B power amp, and am testing the transistors in it, however, some are marked SAE XXX, so I cannot figure out which is the configuration (EBC) or what the replacements would be. I can test the outputs as they are marked EB and the collector is the can. However, the tabbed transistors have SAE marks on them. Was told a while back that one channel is bad, well the outputs all test good, so now it is on to the tabbed transistors. Thanks!
