I'm going to install a power switch but it needs to be polarized due to LED. so I'm going to install a two prong polarized cord or a three prong but I will not ground the chassis. I'm assuming grounding the chassis would not be a good idea. Since I will have the choice on what side the hot will be I'm also assuming hot should go to the fuse and the neutral should go to the thermal cut off correct?
