This has been a problem for a long time now, but can anyone suggest how to identify the fakes by appearance? Current example is 2SA1494; I have some which I believe are genuine (purchased from a legit seller years ago) that weigh close to the 18.4 grams specified in the Sanken datasheet, and some others that weigh less (about 14 grams) that also "look legit" but may not be, that came recently from a different USA surplus seller I've used in the past, which I'm skeptical of. Just measuring them with a Peak tester, and diode test with a trusted Fluke multimeter, the readings are very close. I can post some pics a bit later...
What I'm looking for is any evidence that Sanken may have made some lighter ones late in their production runs, or if all should be in the 18g. range. If their weight was always consistent, then lighter ones can't be real. Or can they?
