Sansui 1000 Wiring Symbols ^ < > # * = ?
adreniline
Probably a basic question for you techies out there, but not knowing enough about electronics, especially from Japan. In the following pictures I have taken, there are symbols on my wiring diagram and on the I guess what you might consider the ledger. The wiring diagram shows a symbol in front of the 30u/10v cap, 170k resistor, 15k resistor etc. In the ledger the same symbol appears, followed by Japanese writing. There are 7 symbols followed by Japanese writing I'm sure if I could read Japaneses my answers would be solved. Anybody have any clue what these seven symbols represent, even a few might be helpful
It probably has something to do with the design or tolerance of the component. Use good quality parts and don't worry too much about it.
- Pete
well done
Thanks for the help, good to run into such knowledgable people. I have received a receiver that has been worked on by other, bad workmanship and a few other issues to remove before I can call it properly restored.
