Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
No sound from left channel yet. I did an adjustment on the bias to now 10 mA was around 60 mA. And adjusted collector voltages to equal half of the outer transistors.
So...new discovery. While cleaning the switch left it on A + B selector and both channels worked. When I put it back to just B left was dead again. Also there is a snapping that seems to come from inside the unit. Not sure if there is arcing or...
To be sure that this is the source of your problem, I would suggest to feed a 1kHz signal directly to the left main in and check the ac voltage with your DMM at the negative leg of the coupling capacitor in the left channel. If you see an AC voltage and it increases with the increasing volume of the phone then the connection between the speaker switch and the coupling capacitor or the switch itself is at fault.
It’s kinda hard to see in that picture but the one contact strip came off the center that turns it. The plastic nubs that hold it on are missing. I’m assuming this is what was causing the missing channel. Maybe I can put some epoxy on it to hold it on. Until a spare part shows itself
I have an old iPhone with a headphone jack. But having trouble finding an app until I update that old phone. I think I might order that switch. Thanks so much for finding it! As far as the part numbers...Sansui didn’t make it easy to find them did they?! Once again, I can’t thank you enough for your help!
