What you said makes since, someone I met recommended this place, they called me on Friday and said the receiver was ready, they changed the bulbs added a jumper wire to keep the dial lights on when on aux and cleaned the boards and claim it is fine. I am going to go pick it up and try it out, if the problem persists I will chalk it up to lesson learned.
QUOTE="larryderouin, post: 11016677, member: 42316"]Shops are there for turnover. The faster they turn over a piece the more profit, conversely The longer a piece of gear sits on the bench, the less profit the shop makes. Replacing caps, even if just one is bad, because you then have to track it down, order it if not in stock and then replace it is generally a loss leader. Generally if a shop doesn't hear anything abnormal in a unit, they'll call it good. And unless you specifically ask for a restoration the normally won't do one as it costs them a tech during the time it takes to restore it. Best to take it to a hobbyiest who has the knowledge and doesn't worry about bench time vs. profit. They'll quote you a set price for a restoration and go thru the whole unit.
Then there are the two schools of thought on caps. One is if they are working, leave them. And the other camp which replaces them after 20-25 years. It's an arguement almost as old as what came 1st.....the chicken or the egg?
The 2000A isn't a hard unit to work on. It just takes patience and a bit of a close eye to details (cap orientation, transistor leg orientation, etc.)[/QUOTE]
