Sansui 2000X shell screws
Pretzelogic
A buddy gave me his old 2000X. I just got it back from the shop all rebuilt and it sounds killer. When I got it it was missing the 4 screws which hold the chassis in the the wooden shell. Audio repair shop I took it to didn’t have any spare ones that fit. Any idea what size these are and where I can get some?
Based upon the other fasteners used for cabinet assembly on the 2000X, they are likely M4-0.7. Length is unknown, but case screws are commonly 8-12mm long. Phillips pan heads are normally used - Well, technically they are JIS "+" recesses, but they are frequently misidentified as Phillips.
OEM fastener is 4X24 mm JIS.
JIS is not used very often any longer but they should be available from an old, established Japanese motorcycle dealer.
Common to handlebar switch assemblies on Honda. To make up for the large dia head, use washers.
The more coarse thread ISO is common now.
