zeferinoj
Member
Hello!
I'm in the process of fixing a Sansui 210, looking at the transistors now. This excellent thread already covers the process but I believed it's based on a later board, an F-1301-4. The one on my set is an F-1301-2, and most noticeably the original transistors are different. I'm looking for comments on the proposed replacements, mostly put together by browsing AK.
ID ---------------- Original --------------- Replacement
TR601/602 2SC871(91F)* KSC1845 (* features a red dot on top)
TR603/604 2SC871(64E) KSC1845
TR701/702 2SC871(64E) KSC1845
TR801/802 2SC694(FD)** KSC1845 (** looks like a little ball, I think it's this one)
TR803/804 2SC634A KSC1845 or KSC1815
TR805/806 2SC634A KSC1845 or KSC1815
TR807/808 2SA678(AD60) KSA992 or KSA1013 (pairing with KSC1845 or KSC1815, respectively)
Also,
All the best,
Joao
Also,
- All the electrolytic capacitors have been replaced on the main board. Should I do the same in the RF one? I'm concerned about the alignment, as I couldn't find instructions for it.
- There are two variable resistors, VR801 and VR802, for "AC balance". On the F-1301-4 schematic there's a 21 V reading next to these variable resistors, across C817 and C818. Should I adjust these until that voltage reads 21 Volts?
- It was relatively easy to spray contact cleaner on the volume pot, but power, bass and treble look sealed. Any ideas on cleaning these?
All the best,
Joao
