americannigh
Right channel only. Thanks for the ideas here. Really appreciate it. If the problem surfaces again then I will do some prodding for cracked or bad joints. I'm leaning towards that now as well knowing that I've replaced all the transistors in the preamp/amp and resistor values check out OK. If it gets to the point where I suspect D002/3 then I would probably swap the diodes and see if the problem migrates to the other channel. Really hope it's not those diodes. There is an area on the board where, when the problem is happening, if I breath on it, then the scratching noise gets worse. I was thinking this meant it was a heat issue but the components in that area all check OK. Maybe the hot breath causes the joint to expand and thus exacerbate a bad joint. Anyway, when I do the caps and new outputs later this week, I'll reflow solder in that area just to be safe.Forgot to ask if the scratchy sound was in both channels or just one?
FYI - have replaced TR701/2 but not TR001.
