I have performed the TSB CE-007A mod on my 3000. I had to sub the driver transistors with KSC2690s but I cant get the bias below 140ma with the trimmers all the way counter- clockwise. I've noticed that my TRZ 2C board has 740ohm resistors ( R821, 824, 827, 830 ) instead of the 800ohm on the schematic, perhaps an earlier revision. What should I be replacing to get the bias down to the 80ma range. Emitter resistors have also been replaced with the 1ohm as suggested in the bulletin.
Any ideas or has someone else experienced this and found a solution?
