Sansui 3000a Balance Issue
Billy1973
Member
I Have recently brought a Sansui 3000a back from the dead. I am amazed on how good this old receiver sounds. The only issue I am having is that the Balance knob has to be set to about the 4:30pm position to balance the sound equally to left and right channels. Has anyone had this problem or does anyone know where I should look to get the Balance closer to the 12 o'clock position?
If you have an oscilloscope and schematic you could feed a 1kHz sine wave into AUX in and check the signal levels through the Amp Driver transistors to see if they are amplifying the signal equally comparing Left to Right at same points. That could help you isolate where the signal is dropping out. Start at the input to each driver board to make sure signal from preamp is equal and move forward or backward accordingly.
Oh man, welcome to old Sansui volume pots. I spent quite a bit of time (and spare pots) trying to correct channel imbalance in a Sansui 800 and a Sansui TR-707 (though yours sounds more serious). The general consensus was, if there wasn't a poor ground somewhere, weak driver transistors in one channel, etc., that some of these old potentiometers weren't so great to begin with and are showing their age. There's a dude on Ebay that sells brand new replacement volumes pots for $90 each but I know nothing about him or his product. I think jd3rdcoast's recommendation to feed a clean sine wave into the 3000A and check the guts with a scope is capital.
I know you've already done this, but did you clean the balance, volume, etc. pots well? Switches? It never ceases to amaze me how just that little bit of oxidization can wreak havoc on an amp. I mention this because I had a receiver with a completely dead channel and I thought I'd burned out something. The good people here convinced me to really clean the pots and that brought the missing channel back. I try to check the really "obvious" things first before pursuing more extreme avenues. Another time I had a channel imbalance in an old JVC. I swapped in another amp--same thing. Turns out my laptop's virtual toggle switch for sound output was kicked over to one side! I never touch that switch so it was a mystery, and every once in a while it slips off center and I have to reset it. Another time I had a bad set of RCA cables, and once I used what looked like RCA cables but were for video only or something---they barely conducted sound!
If that's the only issue you're having with that 3000A you're doing damn good with it! Unrelated to the balance issue, but was the factory mod done to protect speakers from outlandish DC offset?
My 3000A turn the volume all the way down to zero and it is still decently loud. In the workroom just have to turn it up a half increment (the little lines Sansui has circling the volume control) to be at normal listening volume.
One check to wrap your head around if it is the pot is with the unit unplugged do a resistance sweep for both sides (stop at the same points and measure) and see if the two sides are reasonably close. In the middle should be similar.
In the absence of a scope, you could build a simple signal tracer and use it to find the point at which the signal becomes unbalanced.
And yes, I agree that testing the resistance of the balance pot is a good idea...all you need is a multimeter.
I will be pulling that unit out of the rack tomorrow to check the pot. I will replace it temporarily with another 3000a.
Unfortunately I do not have that kind of test equipment
If it turns out that the pot is not the problem, build a simple signal tracer. A much more knowledgeable member provided instructions to me when he was helping me troubleshoot an unbalanced output problem on an early Pioneer solid state receiver.
Here is a link to the thread with the instructions:
https://audiokarma.org/forums/index...dd-problem-hoping-for-some-help.948992/page-3
I had everything I needed on hand in my workshop. but even if you have to buy materials it will only cost a few $$. Pretty danged handy trouble isolation tool.
You will need another amp with which to drive the signal from the amp being tested, and a speaker connected to that amp. I happened to have a cheap little T-amp that someone had given me...used it and a little high-efficiency, full-range Radio Shack speaker.
Basically, the signal tracer is just a probe and a ground wire, with a series capacitor in the probe wire to block DC, soldered into a male RCA jack. Feed a signal into the amp under test (music or test tone), use the probe to test various points in the signal path (comparing left to right) and listen for differences. I made my probe from a 4-5" piece of solid copper Romex, sharpened with a Dremel.
The signal you pick up with the probe goes to the second amp and its speaker, allowing you to easily listen to the signal and ultimately find the point in the signal path where it becomes unbalanced. Fun.
One could probably be made with old PC powered speakers, modifying the input wiring.
Made a custom cable with clips at one end with small film cap to feed an old headphone amp for a simple signal tracer. Helped localize where signal gets screwed up. Otherwise in many amps you are guessing where the problem may be and often end up frustrated and chasing one's own tail. That kind of frustration led me to cobble something together.
Yes, you could certainly buy a cheap set of powered computer speakers and use one of them...no need for a second amp then.
Thank you,,,, I will try that route.
