Sansui 3000A question
tubemusic
AK Subscriber
I have a chance to buy this, but it has the following issue...
Sansui 3000A, right channel works, left channel blows fuses. $25 Plus shipping. @48 Lbs.
I'm new at repair so I was wondering if this would be an easy fix or should I pass it on. Thanks.
Blowing fuses is usually not an "easy" repair if you are not "tech" oriented.
It may be as simple as a blown output.
It may be as complicated as a tore up amp.
It may be a ripped up power supply (bridge rectifier, regulator, etc...).
IIRC the 3000A had a really lousy solder job from the factory (or was that the 2000...).
How much "tech" skill and tools do you have?
Volt Meter
Shouldering Iron
I worked in injection molding, we did some minor wiring and maint on molds.Which were nothing more than replacing heaters and and wiring thermocouples. So nothing major.
http://www.audiokarma.org/forums/showthread.php?t=171462
It has new outputs. Not sure if they are correct though. But if the right channel works? :scratch2:
John.:music::D
IMG_0419 by jleon92f, on Flickr
IMG_0424 by jleon92f, on Flickr
First one fuse , then the other? Weird ? All on Left channel .
