Hello guys, i've been infected by Sansui virus. Now i buy another Sansui 317 after long waiting because its getting harder to find. Plan to buy 5900 but its far more worst, mostly many rust on the back panel.. Then suddenly Sansui 317 show up, then i gofor it. As usual when it arrived, check dc offset, bias. All is done. Then when i play the music, just with 1 click of volume knob rotation, it sounds like a volume of my another amplifier that the volume is around 8-9 oclock. Then i heard a view pops, im rushing to shutdown the amp.
Then i check dc offset, just after relay click, it jump and dancing around 0.2v down to 0.1v then to 0v. In just a view seconds. It is scary right?
I saw a view replaced transistor that does not the original number as in schematic.
Then i did recap and replace all the ecaps except the big reservoir capacitor, and also transistor as in AKers recommend (below is the table that i replace). Also my Sansui 317 has no fuse resistor. After recap done, i did test again, and the volume is a bit better, but still loud. No more pops or crackling. Now the volume knob just 2 clicks from 0 is already loud like the level of casual listening volume. Its around 60-62db. When i check online in a view youtube video, mostly the volume knob is higher than 9 oclock, its like 10 maybe 11 oclock.
The offset still dancing around 0.2vdc after relay click. And the balance is abit to the right, not really centered.
I did check the volume pot visually not replaced yet, still original.
Here is board F-2752 Control Amp transistor table
Any idea from where to start checking ?
I did check roughly after recap, the main voltage after big mylar caps (in my sansui it is in the back of pcb/solder side)
C902 is around 40.5 vdc
C901: 40.46 vdc.
And another power line for relay after C601: 22.13v and 0.006vdc.
Any help would be appreciated.
| PCB NUMBER | SM | Physical (When i get) | Replaced |
| TR01 | 2SA872 D, E | A999 ? | KSA992 |
| TR02 | 2SA872 D, E | No marking | KSA992 |
| TR03 | 2SA906 G,H | A906 | KSA992 |
| TR04 | 2SA906 G,H | No marking | KSA992 |
| TR05 | 2SA906 G,H | A999 ? | KSA992 |
| TR06 | 2SA906 G,H | A906 | KSA992 |
| TR07 | 2SC1775 E,F | C1775 | no |
| TR08 | 2SC1775 E,F | C1775 | no |
C901: 40.46 vdc.
