c.coyle
Fighting the Dunning-Kruger effect.
Don't know how many of these are out there, and it looks like the following problem hasn't been discussed.
I picked up an all original Sansui 350A receiver from the late '60s or earlier '70s. The seller got rid of it because of low and distorted right channel output. This was true on all inputs when I ran it through speakers. But, when I listened through headphones, both channels were fine.
Unlike a lot of receivers with an OFF/A/B/A+B rotary selector, the 350A has a 2 position speaker toggle switch labeled simply A/A+B. A look at the schematic revealed that the speaker cut-off switch is an integral part of the headphone jack, and the amplifier output gets routed through it on the way to the speakers. Pushing in the headphone plug opens contacts for each channel and disconnects the speakers. A little deoxit and some pushing and pulling cleared it up. I'm glad, because the jack is probably unobtainium.
This is a cute little low power, cap coupled receiver. Built like a tank, as was all Sansui gear from that early period. Haven't yet cranked it up, but it seems to run cool. The sound is thin and tinny, so I'll do a recap, a complete power supply rebuild, and a replacement of the 2SC458s. No flying saucers in this one. It also has 8v fuse dial lamps, so they will become LEDs.
