Sansui 4000 fm and pointer lights dim
ducati2
AK Subscriber
My very sweet Sansui 4000 has one issue I want to fix. Both the fm dial pointer light and the fm stereo lights work, but very dim. I’ve gotten into trouble before replacing fm stereo indicator lights, learning they are more complex than a simple aux/phono indicator light, so I’m am a little cautious . Do you think I may have a weak component on the fm board not giving both of these light the voltage they need?
1. Are all of the lamps incandescent? (No LED upgrades)
2. Do all of the other lamps seem to be the proper brightness.
Incandescent lamps over long periods of time can get a dark coating on the inside of the glass, something boils off of the filament.
It may be that simple. Unfortunately the pointer lamp is a very delicate procedure to change. The pointer plastic can be quite brittle and breaks easily.
I have done a few that were really easy, not a lot of glue or the glue turned to dust from the heat. And had a few that were super problematic.
The stereo lamp is pretty simple change and I doubt the problem is with the tuner boards.
Thanks for the reply. The pointer light works, although dim, so I’ll leave that be. I think the fm stereo light is not oem and the wrong spec, waiting for a 6v 100ma now.
FYI, 4000 has two bulbs in the dial pointer. This is because the color of the pointer changes depending on whether AM or FM is selected. Are both lamps dim, or just one?
FM STEREO indicator is generally switched on and off by a transistor on the tuner IF board, and if faulty it is possible that may not be supplying full voltage to the lamp.
First thing would be to do a voltage check at the connection point for each lamp, to see if you are getting full voltage (typically 6-7 volts). Stereo indicator will be DC, most other illumination is typically run on unregulated AC voltage.
