As far as the outputs go, there should be no unsoldering needed. Take the screws out & then just pull them out. You can test them for dead shorts while they're in place, but you'll have to remove them for any further testing.....since you're going to clean/regrease them you'll do it anyway.
For other components you can meter them in circuit to get a general idea if something is amiss. But I wouldn't just randomly start unsoldering things unless you suspect they're bad. The fewer spots you stick your solder iron, the fewer chances you have of lifting a pad/trace.
Take your time & make sure the unit is working properly before you start restoring it. Check the bias & make sure it can be adjusted correctly. Check the voltages at points indicated in the service manual. Write it all down or make note that they're "good", or fix them if they're not. Doing so will help should you encounter a problem later.
Heed Sansuiman's advice in post #11......seriously.
