I just bought a Sansui 4000. The right channel plays great. The left channel blows speaker fuses. The output transistors plus two more transistors on the driver board appear to be shorted after doing a simply diode test with a multimeter. My question is how to physically replace the output transistors. They are surrounded by a heat sink. I took out six screws to try to remove the heat sink block, but that wasn't enough. I figured I would ask here for expert advice before I get in over my head, which maybe I already am. Thanks for any help you can provide.
