I think I discovered some old skooler's method for finding where a problem is. Unfortunately it clashed with my method and I let the smoke out of R829 on the one good amp circuit card and made it match the busted one that the 1980 shop in DC busted.
I'll rephrase. The left channel was working fine as I tested the unit I found in goodwill. I swapped the left channel card into the right channel slot and started a small fire, beginning with the destruction of R829. R815 started to brown afterward I see. Same damage on the originally broken card. I found a rigup using a NAIL in the fuse holder for the right channel. Trouble is, yeah I could replace the 100 quarter watt and the 37k quarter but they'll ignite again. I'm not adept enough with electronics to find the root cause but I've got the repair manual and a fluke 77 I've owned for 28 years.. And I'll be sad tossing the unit so if someone can help me that'd be great. One of you has gotta have a sansui 4000. Soon as I saw that honkin heatsink I knew it was worth rescuing!
