Sansui 4000 transistor help.
Matthew.s
Member
I'm working on a sansui 4000 and I have a bad transistor on the left channel board, board number is F-1150 location of transistor is TR-807 the service manual calls for a 2SC537 A but I am having trouble finding a suitable replacement this is a round aluminum transistor. Any help would be great.
Is it a 2SC or 2SA537? For 2SA537 you can use KSA1220A. Don't be concerned with case style.
Rob
Will this be the correct one?
I also replaced that transistor on my 4000. Yes, the KSA1220YTA is a working replacement.
If you've replaced the caps on the board, go through and check your resistors as well. The 10 ohm resistor, R831 to the left of the 537 that was bad , had drifted to 117k ohms! I had to take the resistor off of the other board, (I replaced it as well), just to double check that it was indeed, that far off. I used a 1/2 watt instead of the 1/4 that was originally in there. It fits easily. There were a few others that had drifted, (not nearly as bad), that I replaced as well, again, using 1/2 watt carbon films.
After replacing the 537 and that resistor, I was able to dial in the bias, whereas before, I couldn't ever seem to get it right.
