Hi All,
One of my friend bought a 4900Z in a very bad condition. It was a long repair, including output transistor, preamp transistor, so called "protection circuit" (even the resistors were blown), some resistors and capacitors.
Anyway, after All adjustments, I tested the system with 8 ohms speakers, as the service manual says 8 ohms only. But on the back plate it states 4 to 16 ohms. My friend used the system with headphones for a while. Though I recommend to use 8 ohms speakers, he managed to find 4 ohms ones. And immediately after he powered the system smoke came out, he says. When I checked the right channel tarnsistors C2579 and A1104 are gone and also A1015 on the right protection circuit.
So though the service manual states 8 ohms, can 4900Z handle 4 Ohms as started in the back plate? The voltage in my country is 220V 50Hz and the serial number of the 4900Z is 831110445.
Thanks in advance...
