Logchop
Hello,
Have a 5000a here with some FM issues, a pretty common thing with this model it seems. I've searched extensively on this site to see if anyone had the exact same problem I'm running into, but haven't seen it. Currently, I'm not able to get any FM in stereo and the sound through FM is muted, as if the muting button is always pressed even for stations that are tuned in. I have confirmed that the stereo light is not burnt out and any audio coming through in FM seems to be in mono, even on strong stations that show good reception on the signal meter. The signal meter and tuning meter work fine. All pots have been cleaned with deoxit including the level pot on the back of the unit and the 75-300 ohm antenna switch.
I've read that mpl251 on the F-1120 board is a common culprit for the FM input being muted, but I've opened up my unit and can't seem to find the F-1120 board. Pictures attached. I was under the impression that the F-1120 board should be located on the underside of the unit between the F-1006a and F-1219 boards. I'm not sure if I'm missing something or if the receiver was altered at some point, it does have a sticker on top of the case saying it was repaired 8-20-87. Unfortunately, that repair did not include updating the F-1040-1 boards, which I also intend on doing following Skippy's method.
I'd appreciate any help finding this F-1120 board, figuring out the FM muting, and figuring out why FM isn't coming through in stereo. Thanks!
