I am new to vintage audio so patience please.
I have a 5000A I want to bring back to life. I ran a line out from the Tape A REC just to see if the radio and phono amp work and everything seems fine when I run it through a separate pre amp/amp.
When I try using any of the three speaker outputs (a, b, or c) via the integrated amp the right channel is out but makes loud pops when I switch the high/low filter and the left channel makes awful noise when I turn it up or down. There is audio from the left - just very low.
I cleaned the pots and switches with a bunch of deoxit. They are very smooth now but that did not help the problem.
I replaced the 4 big capacitors C003 - C006 because the wires looked like they had been hot at one time and because three were discolored and one was an obvious earlier replacement. That did not help but it did not seem to hurt either.
I have the service manual, a digital multimeter, willingness, and lots of time. How do I begin to isolate the issue(s)?
