YapLiMin
Member
Hello AK'ers. Been getting a lot of good information from the forum and appreciate the wealth of knowledge being shared here.
Working on restoring a Sansui 5050 with a F-2701 Power Supply Board. Without getting into too much detail at this time, I'd like to describe the big picture problem I'm having. For the most part the unit was received intact and original except for the F-2647 driver board which was recapped and most of the transistors were missing. So I did the following:
1) Installed new transistor equivalents where missing.
2) Replaced DC bias trim pots with new multi-turn ones.
3) Original Sanken TO-66 2SA765 & 2SC1445 were checked out of circuit on a DMM and were good.
4) Recapped the F-2701 power supply board and the 6800 uF main filter caps.
5) Replaced fusible resistors on F-2701 power supply board.
6) Checked DC offset at speaker terminals are they are just a few mVs (no DC offset trim pots in this unit).
7) Checked and set DC bias to 15 mV per service manual.
So far I've only powered up the unit on a DBT. Unit powers up, speaker relay clicks in after a few seconds and I can tune in FM stations. Rail voltages are close to SM values and unit works fine on both L & R channels and sounds good at low and normal listening levels. However, once I start turning up the volume where it starts getting loud (approx. 1/4 turn or more of volume knob), the DBT increases in brightness and the speaker relay clicks off. When volume is turned down, the DBT goes dimmer, speaker relay clicks on and sound comes back. This happens on both speaker A & B outputs either with 8 ohm dummy loads or 8 ohm speakers attached.
I just so happen to have a Sansui 6060 up next for restoration. Haven't worked any on it yet but it was easy to pop out the F-2647 driver board from it. This board is all original and I swapped it out with the 5050 F-2647 just to see if the issue was with the new electrolytic caps or the new transistors. Alas no difference and the volume issue is still there.
Need suggestions on what to do next to troubleshoot but these are my thoughts:
1) Output transistors malfunctioning during operation even though they check out good on DMM. Replace?
2) Leaky original electrolytic caps on F-2646 tone control board (volume knob here). Recap?
Thanks in advance.
Thanks in advance.
